Tower Toppler (Atari 7800)
Juegos para la consola Atari 7800
ZONADEPRUEBAS
Administrador del Sitio
Gracias dadas: 6 veces
Gracias recibidas: 5 veces
Mensajepor ZONADEPRUEBAS » 15 Oct 2012, 18:42
(por mainframe)
A serious problem is blocking attempts to colonize the otherwise life-compatible planet Nebulus: its water is poisonous! The only way to return the water to its harmless, natural form is to destroy the eight enormous towers that maintain a mysterious, lethal hold over all forms of this valuable resource.
Spurred to action by the needs of your dangerously overpopulated home pianet, you must attempt to conquer these alien-forsaken relics once and for all. But it won t be easy! You ll have to climb each tower all the way to the top in order to detonate its vulnerable spot. And, succeeding towers are more difficult to topple!
You ll need all your wits about you to avoid huge, crushing boulders, giant eyes, and indestructible mutant molecules! And watch out for those slippery stairs and disintegrating ledges. One false step and you ll plummet to the depths below!
Good luck - the hopes of your planet go with you!
Atari 1988
Volver a “Software Atari 7800”
