MUCHO MAS DE LO QUE ESPERABA!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sigue aburriendote por favor....
Voy a intentar montar tu máquina... ;D
GRACIAS!!!!!!!!!!!!
DEFINT A-Z
DECLARE SUB RUNCPU ()
WIDTH 80, 50
DIM SHARED RAM(4096): REM SOLO TIENE UN TOTAL DE 4K DE RAM!
DIM SHARED STACK(16): REM PILA DE MAXIMO DE 16 SALTOS A SUBRUTINAS
DIM SHARED V(16): REM REGISTROS DE VARIABLES DE 0 A F. LA V(F) ES LA DE ESTADOS
DIM SHARED VK(16): REM REGISTROS DE TECLAS DE 0 A F
KR = 0: REM REGISTRO DE TECLA PULSADA (DE 0 A F)
RI = 0: REM REGISTRO INDEXADO "I" DE 12 BITS
PILA = 0: REM DIRECCION DE LA PILA DE RETORNO (MAXIMO 16)
RST = 0: REM RESET SI RST=1
DIR = &H200: REM INICIO DE PROGRAMA SIEMPRE EN LA &H200
CLS
RANDOMIZE TIMER: REM PARA LA SUBRUTINA DE NUMEROS ALEATORIOS
FOR F = 0 TO 15: V(F) = 0: NEXT: REM INICIALIZA LAS VARIABLES
REM CARGA LAS FUENTES EN LA DIRECCION 0 DE LA RAM
D = 0
FOR F = 1 TO 40
READ A
RAM(D) = (A AND &HF0)
D = D + 1
RAM(D) = (A AND &HF) * 16
D = D + 1
NEXT F
FF = 0
AA = 1: BB = 1
DIM FILES$(50): REM max 50 ficheros . OJO!
SHELL "dir /B /ON games >files": REM SEGUN VERSION DEL MSDOS DE WIN98
OPEN "files" FOR INPUT AS 1
WHILE NOT EOF(1)
FF = FF + 1
LINE INPUT #1, FILES$(FF)
WEND
CLOSE 1
INICIO:
FOR F = 1 TO 48 - (48 - FF)
LOCATE F, 1: PRINT F; TAB(6); FILES$(F);
OPEN "GAMES\" + FILES$(F) FOR BINARY ACCESS READ AS 1
A$ = " "
REG& = 1
WHILE REG& < 100
GET #1, REG&, A$
IF A$ = CHR$(0) + CHR$(255) THEN COLOR 6, 0: PRINT TAB(20); "SUPER CHIP8": COLOR 7, 0
REG& = REG& + 2
WEND
CLOSE 1
NEXT
LOCATE AA, 6: COLOR 0, 7: PRINT FILES$(AA); : COLOR 7, 0
1
A$ = UCASE$(INKEY$): IF A$ = "" THEN GOTO 1
IF A$ = CHR$(27) THEN CLS : END
IF LEN(A$) = 2 THEN IF RIGHT$(A$, 1) = "P" THEN AA = AA + 1
IF LEN(A$) = 2 THEN IF RIGHT$(A$, 1) = "H" THEN AA = AA - 1
IF A$ = CHR$(13) THEN N$ = FILES$(AA): CLS : GOTO EMPIEZA
IF AA < 1 THEN AA = FF - 1
IF AA > FF - 1 THEN AA = 1
IF BB <> AA THEN LOCATE BB, 6: COLOR 7, 0: PRINT FILES$(BB); : BB = AA
GOTO 1
EMPIEZA:
FOR F = 8 TO 80 - 7: LOCATE 1, F: PRINT CHR$(254): NEXT
FOR F = 2 TO 33: LOCATE F, 8: PRINT CHR$(254): LOCATE F, 80 - 7: PRINT CHR$(254): NEXT
FOR F = 8 TO 80 - 7: LOCATE 34, F: PRINT CHR$(254): NEXT
OPEN "GAMES\" + N$ FOR BINARY ACCESS READ AS 1
A$ = " "
REG& = 1: REM PARA SUPERCHIP8, PONER 129 EN VEZ DE 1
D = &H200
WHILE NOT EOF(1)
GET #1, REG&, A$: RAM(D) = ASC(A$)
D = D + 1
REG& = REG& + 1
WEND
CLOSE 1
BUCLE:
CALL RUNCPU
IF SALIR = 1 THEN CLS : DIR = &H200: SALIR = 0: GOTO INICIO
GOTO BUCLE
REM DATOS DE LAS FUENTES INTERNAS (SPRITE FONTS) EN LA DIRECCION &H0
REM PARA LOS CARACTERES "0" AL "9", Y "A" A "F" DE 5*8 PIXELS
DATA &Hf9,&H99,&Hf2,&H62,&H27
DATA &Hf1,&Hf8,&Hff,&H1f,&H1f
DATA &H99,&Hf1,&H1f,&H8f,&H1f
DATA &Hf8,&Hf9,&Hff,&H12,&H44
DATA &Hf9,&Hf9,&Hff,&H9f,&H1f
DATA &Hf9,&Hf9,&H9e,&H9e,&H9e
DATA &Hf8,&H88,&Hfe,&H99,&H9e
DATA &Hf8,&Hf8,&Hff,&H8f,&H88
SUB RUNCPU
SHARED RI, DIR, PILA, PAUSA, SALIR
REM RI=REGISTRO INDEXADO
REM CADA VEZ QUE SE EJECUTA UNA INSTRUCCION, DESCUENTA UN 1 A CONTADOR DE PAUSA
PAUSA = PAUSA - 1: : IF PAUSA < 0 THEN PAUSA = 0
REM LEE TECLAS PARA ALMACENAR LA PULSADA EN VK(x)
FOR F = 0 TO 15: VK(F) = 0: NEXT F
INK$ = UCASE$(INKEY$)
TECLA = 0
IF (INK$ >= "0" AND INK$ <= "9") = -1 THEN TECLA = VAL(INK$)
IF (INK$ >= "A" AND INK$ <= "F") = -1 THEN TECLA = VAL("&H" + INK$)
VK(TECLA) = 1
IF INK$ = CHR$(27) THEN SALIR = 1
OPH = RAM(DIR)
OPL = RAM(DIR + 1)
REM SOLO DEBUG
REM GOTO NODEBUG
LOCATE 35, 1
PRINT "DIRECCION:"; HEX$(DIR); " OPCODE:"; HEX$(OPH); " "; HEX$(OPL); " "
PRINT "RI="; HEX$(RI); " "
PRINT "PILA="; PILA; " --> "; HEX$(STACK(PILA)); " "
FOR F = 0 TO 7: LOCATE 40 + F, 40: PRINT "V"; HEX$(F); ":"; HEX$(V(F)); " "; V(F); " ": NEXT
FOR F = 8 TO 15: LOCATE 40 + (F - 8), 60: PRINT "V"; HEX$(F); ":"; HEX$(V(F)); " "; V(F); " ": NEXT
REM A$ = INPUT$(1)
NODEBUG:
DIR = DIR + 2
N0 = (OPH AND &HF0) / 16
N1 = (OPH AND &HF)
N2 = (OPL AND &HF0) / 16
N3 = (OPL AND &HF)
ON N0 + 1 GOTO s0, s1, s2, s3, s4, s5, s6, s7, s8, s9, sa, sb, sc, sd, se, sf
s0:
REM codigos 0 **************************************************************
REM 00E0 --> CLS
IF OPL = &HE0 THEN
CLS
END IF
REM 00EE --> RTS: RETORNO DE SUBRUTINA "JSR (1xxx)"
IF OPL = &HEE THEN
IF PILA = 0 THEN PRINT "ERROR: PILA DE RETORNO VACIA.": END
DIR = STACK(PILA)
PILA = PILA - 1
IF PILA < 0 THEN PILA = 0
END IF
REM 00FF --> HIGH MODE: ACTIVA MODO SUPER CHIP8 (128x64) (EN PRUEBAS)
IF OPL = &HFF THEN
CLS : PRINT "JUEGO DE MODO SUPER CHIP8. NO SOPORTADO POR AHORA.": A$ = INPUT$(1): SALIR = 1
END IF
EXIT SUB
s1:
REM codigos 1 **************************************************************
REM 1xxx --> JMP: SALTO SIN RETORNO (INCONDICIONAL)
DIR = N1 * 256 + OPL
EXIT SUB
s2:
REM codigos 2 **************************************************************
REM 2xxx --> JSR: SALTO CON RETORNO (MAXIMO 16 SALTOS)
PILA = PILA + 1
STACK(PILA) = DIR
IF PILA > 16 THEN PRINT "ERROR: DESBORDAMIENTO DE LA PILA": END
EXIT SUB
s3:
REM codigos 3 **************************************************************
REM 3rxx --> SKEQ VR,XX: SALTAR SIGUIENTE DIRECCION (2 BYTES) SI VR=XX
IF V(N1) = OPL THEN DIR = DIR + 2
EXIT SUB
s4:
REM codigos 4 **************************************************************
REM 4rxx --> SKNE VR,XX: SALTAR SIGUIENTE DIRECCION (2 BYTES) SI VR<>XX
IF V(N1) <> OPL THEN DIR = DIR + 2
EXIT SUB
s5:
REM codigos 5 **************************************************************
REM 5ry0 --> SKEQ VR,VY: SALTAR SIGUIENTE DIRECCION (2 BYTES) SI VR=VY
IF V(N1) = V(N2) THEN DIR = DIR + 2
EXIT SUB
s6:
REM codigos 6 **************************************************************
REM 6rxx --> MOV VR,XX: CARGA REGISTRO V(R) CON XX
V(N1) = OPL
EXIT SUB
s7:
REM codigos 7 **************************************************************
REM 7rxx --> ADD VR,XX: A¥ADE A V(R) EL VALOR XX (SIN ACARREO)
V(N1) = (V(N1) + OPL) AND &HFF
EXIT SUB
s8:
REM codigos 8 **************************************************************
REM 8ry0 --> MOV VR,VY: COPIAR VY EN VR
IF N3 = 0 THEN V(N1) = V(N2): EXIT SUB
REM 8ry1 --> OR VR,VY: "OREAR" VY EN VR
IF N3 = 1 THEN V(N1) = V(N1) OR V(N2): EXIT SUB
REM 8ry2 --> AND VR,VY: "ANDEAR" VY EN VR
IF N3 = 2 THEN V(N1) = V(N1) AND V(N2): EXIT SUB
REM 8ry3 --> XOR VR,VY: "XOREAR" VY EN VR
IF N3 = 3 THEN V(N1) = V(N1) XOR V(N2): EXIT SUB
REM 8ry4 --> ADD VR,VY: A¥ADIR A VR EL VY (SIN ACARREO)
IF N3 = 4 THEN
V(N1) = V(N1) + V(N2)
IF V(N1) > 255 THEN V(N1) = V(N1) AND &HFF: V(&HF) = 1 ELSE V(&HF) = 0
EXIT SUB
END IF
REM 8ry5 --> SUB VR,VY: RESTA A VR EL VY (VF=1 SI <0) **(R - Y)**
IF N3 = 5 THEN
V(N1) = V(N1) - V(N2)
IF V(N1) < 0 THEN V(N1) = 256 + V(N1): V(&HF) = 0 ELSE V(&HF) = 1
EXIT SUB
END IF
REM 8r06 --> SHR VR: ROTA A LA DERECHA EL VR. EL BIT 0 SE CARGA EN VF
IF N3 = 6 THEN V(&HF) = V(N1) AND 1: V(N1) = V(N1) \ 2: EXIT SUB
REM 8ry7 --> RSB VR,VY: RESTA A VY EL VR (VF=1 SI <0) **(Y - R)**
IF N3 = 7 THEN
V(N1) = V(N2) - V(N1)
EXIT SUB
END IF
REM 8r0E --> SHL YR: ROTA A LA IZQUIERDA EL VR. EL BIT 7 SE CARGA EN VF
IF N3 = &HE THEN V(&HF) = (V(N1) AND &H80) / &H80: V(N1) = (V(N1) * 2) AND &HFF
EXIT SUB
s9:
REM codigos 9 **************************************************************
REM 9ry0 --> SKEQ VR,VY: SALTAR SIGUIENTE DIRECCION (2 BYTES) SI VR<>VY
IF V(N1) <> V(N2) THEN DIR = DIR + 2
EXIT SUB
sa:
REM codigos a **************************************************************
REM Axxx --> MVI XXX: CARGA EL INDEXADO CON XXX
RI = N1 * 256 + OPL
EXIT SUB
sb:
REM codigos b **************************************************************
REM Bxxx --> JMI XXX : SALTA A XXX + V0 (VARIABLE 0)
STOP: DIR = (N1 * 256 + OPL) + V(0): REM VERIFICAR
IF DIR > 4096 THEN PRINT "ERROR: DIRECCION DE SALTO FUERA DE 4096": END
EXIT SUB
sc:
REM codigos c **************************************************************
REM Crxx --> RAND VR,XX: CARGA EN V(R) EL DATO ALEATORIO MENOR O IGUAL A XX
V(N1) = RND(1) * OPL
EXIT SUB
sd:
REM codigos d **************************************************************
REM Drys --> SPRITE VR,VY,S : DIBUJA GRAFICO EN "VR,VY" DE ALTURA "S"
X = V(N1)
Y = V(N2)
S = N3
V(&HF) = 0: REM BORRA EL ACARREO
FOR F = 0 TO S - 1
A = RAM(RI + F)
G = 256
WHILE G <> 1
G = G / 2
IF A AND G THEN A$ = CHR$(219) ELSE A$ = CHR$(32)
IF Y > 31 THEN Y = 31: A$ = ""
IF Y < 0 THEN Y = 0: A$ = ""
IF X > 63 THEN X = 63: A$ = ""
IF X < 0 THEN X = 0: A$ = ""
B = SCREEN(Y + 2, X + 9)
IF (A$ = CHR$(219) AND B = 219) = -1 THEN A$ = CHR$(32): V(&HF) = 1: GOTO NOPINTAR
IF (A$ = CHR$(219) AND B = 32) = -1 THEN A$ = CHR$(219): GOTO NOPINTAR
IF (A$ = CHR$(32) AND B = 219) = -1 THEN A$ = CHR$(219): GOTO NOPINTAR
IF (A$ = CHR$(32) AND B = 32) = -1 THEN A$ = CHR$(32): GOTO NOPINTAR
NOPINTAR:
LOCATE Y + 2, X + 9: PRINT A$: X = X + 1
WEND
Y = Y + 1: X = V(N1)
NEXT F
REM AA$ = INPUT$(1)
EXIT SUB
se:
REM codigos e **************************************************************
REM Ek9E --> SKPR K: SALTAR SIGUIENTE DIRECCION (2 BYTES) SI VK(KEY)=1
IF OPL = &H9E THEN IF VK(N1) = 1 THEN DIR = DIR + 2
REM EkA1 --> SKUP K: SALTAR SIGUIENTE DIRECCION (2 BYTES) SI VK(KEY)=0
IF OPL = &HA1 THEN IF VK(N1) = 0 THEN DIR = DIR + 2
EXIT SUB
sf:
REM codigos f **************************************************************
REM Fr07 --> GDELAY VR: CARGA LA PAUSA EN VR
IF OPL = &H7 THEN V(N1) = PAUSA: EXIT SUB
REM Fr0A --> KEY VR: SE PARA EN ESPERA DE UNA TECLA A PULSAR EN VR
IF OPL = &HA THEN
WHILE INK$ = ""
WEND
TECLA = 0
V(N1) = TECLA
EXIT SUB
END IF
REM Fr15 --> SDELAY VR: ACTIVA LA PAUSA SEGUN VR
IF OPL = &H15 THEN PAUSA = V(N1): EXIT SUB
REM Fr18 --> SSOUND VR: EMITE UN SONIDO DE DURACION VR (OJO CON LA DURACION)
IF OPL = &H18 THEN EXIT SUB: REM SOUND 500, V(N1) / 3: EXIT SUB
REM Fr1E --> ADI VR: A¥ADE AL INDEXADO RI EL CONTENIDO DE VR
IF OPL = &H1E THEN
RI = RI + V(N1)
IF RI > 4095 THEN RI = RI - 4096
EXIT SUB
END IF
REM Fr29 --> FONT VR: HACE QUE EL INDEXADO RI APUNTE AL CARACTER VR
IF OPL = &H29 THEN RI = (V(N1) AND &HF) * 5: EXIT SUB
REM Fr33 --> BCD VR: ALMACENA EN "RI,RI+1,RI+2" EL BCD DEL VR
IF OPL = &H33 THEN
A$ = LTRIM$(RTRIM$(STR$(V(N1))))
IF LEN(A$) = 1 THEN A$ = "00" + A$
IF LEN(A$) = 2 THEN A$ = "0" + A$
B = VAL(MID$(A$, 1, 1))
C = VAL(MID$(A$, 2, 1))
D = VAL(MID$(A$, 3, 1))
RAM(RI + 0) = B
RAM(RI + 1) = C
RAM(RI + 2) = D
EXIT SUB
END IF
REM Fr55 --> STR V0-VR: ALMACENA (PUSH) LOS REGISTROS DE V(0) A V(R) EN RI
IF OPL = &H55 THEN
FOR F = 0 TO N1
RAM(RI) = V(F)
RI = RI + 1
NEXT
EXIT SUB
END IF
REM Fr65 --> LDR V0-VR: RECUPERA (POP ) LOS REGISTROS DE V(0) A V(R) DE RI
IF OPL = &H65 THEN
FOR F = 0 TO N1
V(F) = RAM(RI)
RI = RI + 1
NEXT
EXIT SUB
END IF
END SUB
Joss escribió:(hoy estais aportando posts muy interesantes ........ muchas gracias )
Hark0, porque no implementas un emulador de una máquina universal de Turing? No he mirado los detalles, pero debe ser de los computadores mas sencillos que hay:
http://en.wikipedia.org/wiki/Turing_machine
DEFINT A-Z
'WIDTH 80, 50
Screen 20
DIM SHARED RAM(4096): ' SOLO TIENE UN TOTAL DE 4K DE RAM!
Dim Shared RI, DIRF, PILA, PAUSA, SALIR, VK, TECLA, I$
DIM SHARED STACK(16): ' PILA DE MAXIMO DE 16 SALTOS A SUBRUTINAS
DIM SHARED V(16): ' REGISTROS DE VARIABLES DE 0 A F. LA V(F) ES LA DE ESTADOS
DIM SHARED VT(16): ' REGISTROS DE TECLAS DE 0 A F
TECLA = 255
VK = 255: ' REGISTRO DE TECLA PULSADA (DE 0 A F) (255= NINGUNA)
RI = 0: ' REGISTRO INDEXADO "I" DE 12 BITS
PILA = 0: ' DIRECCION DE LA PILA DE RETORNO (MAXIMO 16)
DIRF = &H200: ' INICIO DE PROGRAMA SIEMPRE EN LA &H200
CLS
RANDOMIZE TIMER: ' PARA LA SUBRUTINA DE NUMEROS ALEATORIOS
FOR F = 0 TO 15: V(F) = 0: NEXT: ' INICIALIZA LAS VARIABLES
' CARGA LAS FUENTES EN LA DIRECCION 0 DE LA RAM
D = 0
FOR F = 1 TO 40
READ A
D = D + 1
D = D + 1
NEXT F
FF = 0
AA = 1: BB = 1
DIM FILES$(50): ' max 50 ficheros . OJO!
SHELL "dir /B /ON games >files": ' SEGUN VERSION DEL MSDOS DE WIN98
WHILE NOT EOF(1)
FF = FF + 1
WEND
CLOSE 1
INICIO:
A$ = " "
REG& = 1
WHILE REG& < 150
GET #1, REG&, A$
REG& = REG& + 2
WEND
CLOSE 1
NEXT
1
GOTO 1
EMPIEZA:
A$ = " "
REG& = 1
D = &H200
WHILE NOT EOF(1)
D = D + 1
REG& = REG& + 1
WEND
CLOSE 1
BUCLE:
CALL RUNCPU
IF TECLA <> 255 THEN GOTO 22
I$ = INKEY$
22
IF I$ = CHR$(27) THEN SALIR = 1
IF (I$ >= "0" AND I$ <= "9") = -1 THEN VK = VAL(I$)
IF (I$ >= "A" AND I$ <= "F") = -1 THEN VK = VAL("&H" + I$)
IF I$ = " " THEN VK = 5
IF LEN(I$) = 2 THEN
I$ = RIGHT$(I$, 1)
IF I$ = "H" THEN VK = 2
IF I$ = "P" THEN VK = 8
IF I$ = "K" THEN VK = 4
IF I$ = "M" THEN VK = 6
END IF
IF TECLA <> 255 THEN V(TECLA) = VK: TECLA = 255
IF SALIR = 1 THEN
' RESET
CLS
DIRF = &H200
SALIR = 0
PILA = 0
VK = 255
RI = 0
GOTO INICIO
END IF
GOTO BUCLE
' DATOS DE LAS FUENTES INTERNAS (SPRITE FONTS) EN LA DIRECCION &H0
' PARA LOS CARACTERES "0" AL "9", Y "A" A "F" DE 5*8 PIXELS
SUB RUNCPU
' RI=REGISTRO INDEXADO
FOR F# = 0 TO 1000: NEXT: ' PAUSA DE PRUEBAS
' CADA VEZ QUE SE EJECUTA UNA INSTRUCCION, DESCUENTA UN 1 A CONTADOR DE PAUSA
OPH = RAM(DIRF)
OPL = RAM(DIRF + 1)
' SOLO DEBUG
' GOTO NODEBUG
LOCATE 35, 1
PRINT "DIRECCION:"; HEX$(DIRF); " OPCODE:"; HEX$(OPH); " "; HEX$(OPL); " "
' IF DIRF > &H380 THEN A$ = INPUT$(1)
NODEBUG:
DIRF = DIRF + 2
N1 = (OPH AND &HF)
N3 = (OPL AND &HF)
s0:
' codigos 0 **************************************************************
' 00E0 --> CLS
IF OPL = &HE0 THEN
CLS
END IF
' 00EE --> RTS: RETORNO DE SUBRUTINA "JSR (1xxx)"
IF OPL = &HEE THEN
DIRF = STACK(PILA)
PILA = PILA - 1
END IF
' 00FF --> HIGH MODE: ACTIVA MODO SUPER CHIP8 (128x64) (EN PRUEBAS)
IF OPL = &HFF THEN
END IF
EXIT SUB
s1:
' codigos 1 **************************************************************
' 1xxx --> JMP: SALTO SIN RETORNO (INCONDICIONAL)
DIRF = N1 * 256 + OPL
EXIT SUB
s2:
' codigos 2 **************************************************************
' 2xxx --> JSR: SALTO CON RETORNO (MAXIMO 16 SALTOS)
PILA = PILA + 1
STACK(PILA) = DIRF
EXIT SUB
s3:
' codigos 3 **************************************************************
' 3rxx --> SKEQ VR,XX: SALTAR SIGUIENTE DIRECCION (2 BYTES) SI VR=XX
IF V(N1) = OPL THEN DIRF = DIRF + 2
EXIT SUB
s4:
' codigos 4 **************************************************************
' 4rxx --> SKNE VR,XX: SALTAR SIGUIENTE DIRECCION (2 BYTES) SI VR<>XX
IF V(N1) <> OPL THEN DIRF = DIRF + 2
EXIT SUB
s5:
' codigos 5 **************************************************************
' 5ry0 --> SKEQ VR,VY: SALTAR SIGUIENTE DIRECCION (2 BYTES) SI VR=VY
IF V(N1) = V(N2) THEN DIRF = DIRF + 2
EXIT SUB
s6:
' codigos 6 **************************************************************
' 6rxx --> MOV VR,XX: CARGA REGISTRO V(R) CON XX
V(N1) = OPL
EXIT SUB
s7:
' codigos 7 **************************************************************
' 7rxx --> ADD VR,XX: A¥ADE A V(R) EL VALOR XX (SIN ACARREO)
EXIT SUB
s8:
' codigos 8 **************************************************************
' 8ry0 --> MOV VR,VY: COPIAR VY EN VR
' 8ry1 --> OR VR,VY: "OREAR" VY EN VR
' 8ry2 --> AND VR,VY: "ANDEAR" VY EN VR
' 8ry3 --> XOR VR,VY: "XOREAR" VY EN VR
' 8ry4 --> ADD VR,VY: A¥ADIR A VR EL VY (SIN ACARREO)
IF N3 = 4 THEN
EXIT SUB
END IF
' 8ry5 --> SUB VR,VY: RESTA A VR EL VY (VF=1 SI <0) **(R - Y)**
IF N3 = 5 THEN
EXIT SUB
END IF
' 8r06 --> SHR VR: ROTA A LA DERECHA EL VR. EL BIT 0 SE CARGA EN VF
' 8ry7 --> RSB VR,VY: RESTA A VY EL VR (VF=1 SI <0) **(Y - R)**
IF N3 = 7 THEN
IF V(N1) < 0 THEN V(N1) = 256 + V(N1): V(&HF) = 1 ELSE V(&HF) = 0
' AQUI
EXIT SUB
END IF
' 8r0E --> SHL YR: ROTA A LA IZQUIERDA EL VR. EL BIT 7 SE CARGA EN VF
EXIT SUB
s9:
' codigos 9 **************************************************************
' 9ry0 --> SKEQ VR,VY: SALTAR SIGUIENTE DIRECCION (2 BYTES) SI VR<>VY
IF V(N1) <> V(N2) THEN DIRF = DIRF + 2
EXIT SUB
sa:
' codigos a **************************************************************
' Axxx --> MVI XXX: CARGA EL INDEXADO CON XXX
RI = N1 * 256 + OPL
EXIT SUB
sb:
' codigos b **************************************************************
' Bxxx --> JMI XXX : SALTA A XXX + V0 (VARIABLE 0)
DIRF = (N1 * 256 + OPL) + V(0): ' VERIFICAR
IF DIRF > 4096 THEN PRINT "ERROR: DIRECCION DE SALTO FUERA DE 4096": END
EXIT SUB
sc:
' codigos c **************************************************************
' Crxx --> RAND VR,XX: CARGA EN V(R) EL DATO ALEATORIO MENOR O IGUAL A XX
EXIT SUB
sd:
' codigos d **************************************************************
' Drys --> SPRITE VR,VY,S : DIBUJA GRAFICO EN "VR,VY" DE ALTURA "S"
X = V(N1)
Y = V(N2)
S = N3
V(&HF) = 0: ' BORRA EL ACARREO
FOR F = 0 TO S - 1
A = RAM(RI + F)
G = 256
WHILE G <> 1
ER = 0
G = G / 2
IF Y > 31 THEN ER = 1
IF Y < 0 THEN ER = 1
IF X > 63 THEN ER = 1
IF X < 0 THEN ER = 1
IF ER = 0 THEN B = SCREEN(Y + 2, X + 9)
NOPINTAR:
IF ER = 0 THEN LOCATE Y + 2, X + 9: PRINT A$: X = X + 1
WEND
NEXT F
' AA$ = INPUT$(1)
EXIT SUB
se:
' codigos e **************************************************************
' Ek9E --> SKPR K: SALTAR SIGUIENTE DIRECCION (2 BYTES) SI VT(KEY)=1
IF OPL = &H9E THEN IF V(N1) = VK THEN DIRF = DIRF + 2: VK = 255
' EkA1 --> SKUP K: SALTAR SIGUIENTE DIRECCION (2 BYTES) SI VT(KEY)=1
' OJO ESTAN AL REVES, ESTUDIARLO CON EL BRIX
IF OPL = &HA1 THEN IF V(N1) = VK THEN VK = 255 ELSE DIRF = DIRF + 2
EXIT SUB
sf:
' codigos f **************************************************************
' Fr07 --> GDELAY VR: CARGA LA PAUSA EN VR
' Fr0A --> KEY VR: SE PARA EN ESPERA DE UNA TECLA A PULSAR EN VR
IF OPL = &HA THEN
WHILE I$ = "": I$ = UCASE$(INKEY$): WEND
TECLA = N1: ' OBLIGA A QUE AL SALIR SE META EN V(N1) EL VALOR DE LA TECLA
EXIT SUB
END IF
' Fr15 --> SDELAY VR: ACTIVA LA PAUSA SEGUN VR
' Fr18 --> SSOUND VR: EMITE UN SONIDO DE DURACION VR (OJO CON LA DURACION)
IF OPL = &H18 THEN EXIT SUB: ' SOUND 500, V(N1) / 3: EXIT SUB
' Fr1E --> ADI VR: A¥ADE AL INDEXADO RI EL CONTENIDO DE VR
IF OPL = &H1E THEN
RI = RI + V(N1)
EXIT SUB
END IF
' Fr29 --> FONT VR: HACE QUE EL INDEXADO RI APUNTE AL CARACTER VR
' Fr33 --> BCD VR: ALMACENA EN "RI,RI+1,RI+2" EL BCD DEL VR
IF OPL = &H33 THEN
RAM(RI + 0) = B
RAM(RI + 1) = C
RAM(RI + 2) = D
EXIT SUB
END IF
' Fr55 --> STR V0-VR: ALMACENA (PUSH) LOS REGISTROS DE V(0) A V(R) EN RI
IF OPL = &H55 THEN
FOR F = 0 TO N1
RAM(RI) = V(F)
RI = RI + 1
NEXT
EXIT SUB
END IF
' Fr65 --> LDR V0-VR: RECUPERA (POP ) LOS REGISTROS DE V(0) A V(R) DE RI
IF OPL = &H65 THEN
FOR F = 0 TO N1
V(F) = RAM(RI)
RI = RI + 1
NEXT
EXIT SUB
END IF
END SUB
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 39 invitados
